1.9 TDI (AWX) Audi A4 runs roughly when idling.
McGiver
Post25-06-2008, 10:50    Subject: 1.9 TDI (AWX) Audi A4 runs roughly when idling. Quote
Hello everyone,
I've been having problems with my 1.9 TDI 96kW engine (AWX) for the past three weeks. It's running intermittently.
When idling, the engine runs unevenly, as if the fuel injection amount is too low. The idle speed control also seems plausible. All other values are also OK. The compression is also within the optimal range. Air filters and fuel filters have been replaced.
No performance loss, no blue smoke or soot.
The oil consumption is approximately 1/4 liter per 5000 km.
What surprises me... the idle consumption has decreased from 0.6 l/h to 0.3 l/h.
The overall consumption has also decreased from 5.8 to 4.7 l/100km at the moment.
I hope someone can help me out!!
Greetings to everyone
No new posts Ford mit TDCi, Motor läuft unrund, geht aus General Tips
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Motor läuft nur mit 500 U/min, nimmt kein Gas an, 81KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 2.5 TDI, Engine 180 hp, running unevenly Diesel Engine Technology
No new posts AFN läuft unrund Diesel Engine Technology
No new posts 1.4 TDI engine idling roughly Diesel Engine Technology
No new posts Idle running rough - faulty PCV valve? Gasoline Engine Technology
