Swapping suspension springs on a VW Eos
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bakkano
Post25-06-2008, 14:38    Subject: Swapping suspension springs on a VW Eos Quote
My girlfriend bought an Eos.
2.0 TDI.
It has the standard suspension.
Part numbers for springs 1K0 411 105. PR-2UA+L19
I would like it to be a bit more staggered.
I've already looked up the part numbers for other springs from the Eos.
There are only 2 letters at the end that are different.
Go from.
1K0...DA PR2UC+L55
1K0...DB PR2UC+L58
1K0...DC PR2UC+L59
1K0...DD PR2UC+L62
1K0...DE PR2UC+L63
1K0...DF PR2UC+L68
Which one can I take?
Karma: +642 / -0   Thank you, like it!
Post25-06-2008, 18:01    Subject: Swapping suspension springs on a VW Eos Quote
A subtle lowering kit from a reputable manufacturer is the best option; for example, FK is not a brand I would recommend.
It might still be cheaper than the Orschinols garbage, which only works properly when used with the matching dampers.
Best regards, Rüdi.
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GTI springs Transmission, Chassis, Body & Interior
No new posts Feathers of steel? Transmission, Chassis, Body & Interior
No new posts Einstellscheiben Federn HD-Teil an der Einspritzpumpe v. ALH Diesel Engine Technology
No new posts 1J 4-Motion - Verspannen der hinteren Federn Transmission, Chassis, Body & Interior
