kalle wrote: |
There is an adjustment screw at the top of the accelerator pedal! What and to what extent should you adjust it? Perhaps the preload of the short throttle cable? In the EDC, idle is 0% and full throttle is 100%.
Or does the accelerator pedal need to be re-calibrated to the control unit? |
Hi Kalle,
If the sensor reaches 100% approximately 1 cm before the bottom of the pedal travel, the sensor is optimally adjusted.
That's it, no learning or anything like that required.
