Headlight Range Control Passat 3B Faulty
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
olli
Karma: +46 / -0   Thank you, like it!
Post27-08-2008, 11:19    Subject: Headlight Range Control Passat 3B Faulty Quote
Our company car, a 3B variant from 1999, had some minor issues during its recent technical inspection (TÜV).
"For example, the low beam function doesn't work at all. Does this model (with H7 headlights) still use a potentiometer for controlling the motors, or is everything already controlled by the onboard computer?"
Does anyone happen to have a circuit diagram excerpt?
Best regards from Berlin.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 28-08-2026, 2:04.
pax
Avatar-pax
2000 Volkswagen Passat
Post27-08-2008, 19:49    Subject: Headlight Range Control Passat 3B Faulty Quote
Also, also take a look at the mechanics. In my case, the rod that transmits the movement to the reflector had come loose.
Bye.
peace
Translated on 28-08-2026, 2:05.
olli
Post28-08-2008, 10:11    Subject: Headlight Range Control Passat 3B Faulty Quote
It was actually a mechanical problem.
Thank you.
Olli.
A6 CANA/JME /
Ex-A6 AEL
No new posts Doku Passat MJ 2000 Beleuchtung Sonnenblende defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 111kW AHY, auxiliary heater defective Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Biodiesel Passat V6 TDI: ESP Failure Fix Diesel Engine Technology
No new posts Passat 3B V6 TDI: MSTG Failure? On-Board Diagnostics (OBD)
No new posts Mass Air Flow Sensor Problem: VW Passat Variant 2.5 TDI Diesel Engine Technology
No new posts Active speakers faulty in VW Passat 35i Transmission, Chassis, Body & Interior
