BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
14-04-2007, 18:34 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
"For the past 2 years, I've been having issues with the mirror adjustment on my B5. Occasionally, it only works in the X-axis (outwards) and the Y-axis (upwards). Sometimes, when I don't need it, it works perfectly."
It doesn't matter which position the switch is in. In position "x", the right mirror will move outwards, while in position "Y", it will always move upwards. Sometimes, the mirrors might only move upwards or outwards, depending on the vehicle's "mood." At this moment, the left mirror also no longer has a plausible function.
Unfortunately, it has always been the case (and it's happening again today) that the adjustment works perfectly whenever I get close to the vehicle with VagCom  . The error memory is, of course, empty, and all functions are plausible through the measuring blocks.
"There are no cable breaks, and all other functions related to the comfort control module are working correctly. If I can't find the source of the problem, I will start by replacing the mirror switch, although I can't imagine that the switch itself is malfunctioning."
Does anyone have any advice? 3B5 AJM
Translated on 19-10-2026, 1:08.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
15-04-2007, 5:20 Subject: Electric Mirror Adjustment Malfunction |
BM wrote: | If I can't find it, I will start by replacing the mirror switch, although I can't imagine such a malfunction of the switch.
Who knows the answer? |
"In the previous models, the 35i and 3A, this issue was also frequently observed and was often caused by the switch."
Translated on 19-10-2026, 1:10.
Profile PM Garage |
matze Guest
17-04-2007, 15:31 Subject: Electric Mirror Adjustment Malfunction |
'There are no cable breaks, and all other functions related to the comfort control module are working correctly. If I can't find the source of the problem, I will start by replacing the mirror switch, although I can't imagine that the switch itself is malfunctioning.'
Have you ever looked at the motors inside the rearview mirror housing and their wiring? There might be some chafing or damage there.
Matthias.
Translated on 19-10-2026, 1:11.
BM Profi-Schrauber
17-04-2007, 20:29 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
Quote: | | Have you ever looked at the motors in the rearview housing and their wiring? | There might be some chafing there.
Okay, last year when the mirror housings were repainted, I didn't notice anything. But the problem occurs on both mirrors. Still, thanks for the tip. I'll check it out sometime (if I have the time). 3B5 AJM
Translated on 19-10-2026, 1:12.
matze Guest
19-04-2007, 15:31 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
I just remembered something: Please check (if you haven't already) the rubber hose between the body and the door. In my case, there were already two cables that had passed through it - it caused a very interesting error pattern.
Translated on 19-10-2026, 1:13.
BM Profi-Schrauber
15-08-2008, 20:47 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
Finally found the time after a long period.
Solution - Faulty switch  3B5 AJM
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
05-09-2008, 19:40 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
Let me join in.
T4 2002, both mirrors without adjustment function, the switch has been replaced without success. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
08-09-2008, 8:45 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
teileklaus wrote: | | T4 2002, both mirrors without adjustment function, the switch has been replaced without success. |
Hi Klaus,
The information is rather sparse  .
How about the door locking mechanism and cable routing?
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 19-10-2026, 1:14.
Profile PM Garage |
08-09-2008, 20:19 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
"You're right, Guste."
Nothing is working, no matter what I try. The fuse is fine, and the things that are fuse-protected are working. The cables will be checked at the next opportunity. I would have liked to swap the mirrors with working ones for testing, but I would have to remove all the trim to do that. The vehicle should be running.
Can I see the mirror adjustment function in VAG Com? And if so, where? Gruß, der Teileklaus
Translated on 19-10-2026, 1:15.
BM Profi-Schrauber
08-09-2008, 21:37 Subject: Mirror Adjustment Malfunction: Troubleshooting Guide |
Quote: | | Can I actually see the mirror adjustment function in VAG Com? And if so, where? |
This happens in one of the measurement blocks of the comfort control system. In my case, they only worked when I connected to the vehicle using VAGCOM. 3B5 AJM
Translated on 19-10-2026, 1:16.
