Boost Lag & Soot: Causes and Solutions
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
tsfreak
Post08-09-2008, 12:19    Subject: Boost Lag & Soot: Causes and Solutions Quote
Hello!
Could someone please take a look at the log and let me know what might be causing the slow LD build-up or the soot formation at full load?
As far as I can tell, the smoke limiter is active. Is that possible? And if so, how do I fix it?
Lufi, new.
Diesel filter, new.
Vacuum system sealed (new hoses installed).
Thank you very much!
Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 17:54.
Post08-09-2008, 13:13    Subject: Boost Lag & Soot: Causes and Solutions Quote
I am unable to access external URLs, so I cannot translate the text from the provided link. Please provide the text directly, and I will be happy to translate it for you.
Please organize the log.
Translated on 28-09-2026, 17:55.
tsfreak
Post08-09-2008, 13:33    Subject: Boost Lag & Soot: Causes and Solutions Quote
Sorry, I've uploaded it again as an xls file. I hope that's okay.
Translated on 28-09-2026, 17:56.
Post08-09-2008, 16:45    Subject: Turbo Lag & Soot: Troubleshooting Guide Quote
tsfreak wrote:
Could someone please take a look at the log and let me know if they can identify the cause of the slow LD build-up or the soot formation at full load?
As far as I can see, the smoke limit is active.
Could that be the case?
Correct.
And if so, how do I fix it?}By either having your chip tuner physically access the roof of the car, or by retrieving the original software.
tsfreak
Post08-09-2008, 21:58    Subject: Boost Lag & Soot: Causes and Solutions Quote
Thank you, Ulf, for your effort and your clear statement.
Sure, it's not software from a top-tier tuner. But could it be that it doesn't account for the faulty EGR valve, and that's why the problem is occurring?
Translated on 28-09-2026, 17:57.
Post09-09-2008, 5:22    Subject: Boost Lag & Soot: Causes and Solutions Quote
tsfreak wrote:
Could it be that he didn't take into account the faulty EGR valve, and that's why the problem occurred?
Whether it's the standard configuration or "normally" tuned, if a defective EGR valve is "always closed," it cannot produce more soot than a functioning EGR valve.
I haven't looked into whether it would be possible to force the software to work in that way, because I don't have enough time to explore all the possible and unusual ways it could be misused.
As long as there isn't a mechanical defect causing excessive soot production, your black smoke is likely simply indicating the "quality" of the tuning software.
The LD (Lean Definition) setup wouldn't be faster even with an active (instead of blocked) EGR system; it would likely be even slower. The software offers various parameters that can be adjusted to improve the result, but if the tuner doesn't know what they're doing, they can actually make things worse.
No software from a high-end tuner
. With high-end tuners, you can only be sure of one thing: that you are financing their representative office / luxury building with the price you pay for the tuning. icon_wink.gif
Translated on 28-09-2026, 17:59.
tsfreak
Post09-09-2008, 6:57    Subject: Boost Lag & Soot: Causes and Solutions Quote
Okay, I understand. I'll look into that colleague's behavior.
Anyway, now that I've solved several other problems, I know where I still need to take action.
Translated on 28-09-2026, 18:00.
Post09-09-2008, 9:57    Subject: Boost Lag & Soot: Causes and Solutions Quote
tsfreak wrote:
I'm going to check out that colleague
a bit. :twisted:Getting work done by colleagues is cheap, but sometimes it's not even worth the price. }
Translated on 28-09-2026, 18:01.
tsfreak
Post10-09-2008, 6:20    Subject: Boost Lag & Soot: Causes and Solutions Quote
It's probably true.
However, I have one more question. I've noticed that when, for example, during a log run with boost pressures of 1200-4000, the boost is generally fine and there are no overshoots. However, during normal driving, these overshoots appear. For example, in 5th or 6th gear, the boost might reach 120 when accelerating quickly. So, when I suddenly press the accelerator.
Can you confirm this behavior? Is this normal, or is there something else wrong?
I had already adjusted the VTG rod as far as it would go, and the load distribution was perfect. There were no oscillations or overshoots. It was running great. I parked the car in the evening, and the next day I had excessive oscillations again. Could it be a temperature sensor?
Translated on 28-09-2026, 18:02.
Post10-09-2008, 7:50    Subject: Boost Lag & Soot: Causes and Solutions Quote
Quote from the terms of service of this forum, found at: /faq.php.
/faq.php wrote:
Questions about (...) other tuning products that are not (...) available from this online shop will be deleted without comment. Support for EBAY products or products from competitors is the responsibility of the respective seller.
Therefore, we are now closing.
Translated on 28-09-2026, 18:03.
No new posts Boost Pressure Slow, Target Value Too Low Diesel Engine Technology
No new posts VCDS Logs: Slow Boost & Soot Issues Upload
No new posts Heated Seats: Slow to Warm Up? Diesel Engine Technology
No new posts Slow-reacting heated seats Transmission, Chassis, Body & Interior
