My sister now owns my old Seat A2 1.4 TDI, and it was starting worse and worse. So, I took it to the
Diesel and air filters are in good condition.
Bypass pump in good working order.
Spark plugs in good condition.
120,000 km - all inspections completed.
The workshop was about to give up, as the problem only occurred sporadically, but then:
The seals of the PD elements were replaced because they were completely mechanically damaged, which resulted in a loss of compression.
Okay, here's the translation:
"Now things get serious: the valve seats in the cylinder head have significant marks/wear. While new seals are installed now, no one can tell us how long they will last."
Als Lösung wurde ein Zylinderkopftausch samt neuer PD Elemente, Nockenwellen ect. angeboten. Costs €3,000.
I have absolutely no idea how something like that could happen. Even a Google search didn't turn up anything useful.
Does anyone else experience this problem, or have any insights?
Best regards, David, who has run out of ideas on this matter.
