Suche (Motor)CAN-Anschluss im Golf IV | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Chr_Meissner
Post18-09-2008, 21:25    Subject: Quote
What is the part number of your instrument cluster?
VAG No. 1JO 920 806 G (Alternatives: 1J0 920 800 G; own handwriting illegible icon_wink.gif, Coding 01112.
However, since then, my airbag light has been on!
I also had an error code in the diagnostic tool: "01336", which, according to the VAGFORUM, means "Data Bus for Comfort System," followed by "80-10" = "Single Wire Operation - Intermittent." It seems that it really was the comfort CAN bus that I tapped into at pins 8/9. I need to check again why there were no data signals coming through there.
Is there any interest in corresponding hardware and software?
I have a universal hardware device from KOPFWEB. It comes with a DLL that allows you to access the USB-CAN interface from any custom-written (C++) program. It works great. I'll need this later for work (CAN connection between the central control unit and the 70kW electric motor controller; I'm already gaining experience with CAN bus). Also, very simple controllers (e.g., C-Control II) have both USB and CAN connections. However, FlexRay is the technology of the future.
Christian.
Golf 4 Variant 1.9TDI 74kW AXR 10/2002 Biodiesel
Translated on 02-08-2026, 18:38.
axmax
Post18-09-2008, 22:08    Subject: Quote
Chr_Meissner wrote:
VAG part number 1JO 920 806 G (Alternatives: 1J0 920 800 G; own handwriting illegible icon_wink.gif Coding 01112
806 (0 = no MFA, no FIS, 6 = WFS 3)
I am 99.9% sure that the WFS3 AI systems have a Comfort-CAN. Perhaps your comfort control unit doesn't yet have a CAN bus, and therefore the AI has nothing to communicate with it icon_smile.gif.
If the AI is connected to the desk, the Comfort-CAN might not automatically start sending data. However, simply sending a message on the CAN bus should initiate it. Nothing should break, except perhaps some error codes might appear.
"Bitte gib mir den Text, den du übersetzt haben möchtest."
If you're looking for something to play with indoors – it's getting colder after all – then consider an "Audi Chorus 2". You can find them on eBay for around EUR 30, and they are CAN-bus compatible and transmit data automatically. If you also get an Audi 8E instrument cluster (KI), you can create a great testing environment. The selected radio channel will then be displayed on the FIS (Multi Function Instrument).
Audi A4 B6 BFC
Translated on 02-08-2026, 18:41.
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATL Engine Mass Air Flow Sensor (MAF) Blocks On-Board Diagnostics (OBD)
No new posts Looking for instructions on how to replace the camshaft o... Diesel Engine Technology
No new posts VW AGK Engine: Specs, Problems, & More Diesel Engine Technology
No new posts TDI PD Engine: Find Your Specific ET Number Diesel Engine Technology
