AAT Cylinder Head: Fits 1T Engine Block?
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post20-09-2008, 20:46    Subject: AAT Cylinder Head: Fits 1T Engine Block? Quote
The probability is likely to be very high that it will work out.
Does anyone know more precisely?
1T = 2.5L TDI 5-cylinder Audi 100 Type 44 (1989 to 1990)
AAT = 2.5 liter TDI 5-cylinder Audi 100 (1990 to 1994)
The cylinder heads are not identical; the AAT engine has a vacuum pump driven by the camshaft mounted on the cylinder head, while the 1T engine does not. Otherwise, the heads should be the same, or so I suspect.
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 08-10-2026, 2:30.
christians
Post20-09-2008, 21:46    Subject: AAT Cylinder Head: Fits 1T Engine Block? Quote
??? How does the 1T engine then create the vacuum? This pump was also used in the 5-series gasoline engines.
Gruß Christian
Translated on 08-10-2026, 2:31.
Jens 16syncro
Post21-09-2008, 11:00    Subject: AAT Cylinder Head: Fits 1T Engine Block? Quote
christians wrote:
??? How does the 1T then create the vacuum?
Not at all.
In the Audi 100, Type 44, the power brake booster (and other comfort functions) operate via the hydraulic system.
Starting with the C4 model (model year 1991, manufactured around the mid-1990s), a vacuum-operated power brake booster is used again.
Jens.
Translated on 08-10-2026, 2:32.
christians
Post21-09-2008, 22:38    Subject: AAT Cylinder Head: Fits 1T Engine Block? Quote
You're right, I had forgotten, even though I had a really tough time with it back then.
Gruß Christian
Translated on 08-10-2026, 2:33.
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motorblock hat ab 110000 km einen 3 cm riss Diesel Engine Technology
No new posts Is the clutch working properly? Diesel Engine Technology
No new posts Does this control unit fit? On-Board Diagnostics (OBD)
No new posts Intercooler for A3 with AGR: Will it fit? Diesel Engine Technology
