Neues Steuergerät an vorhandene WFS anpassen | Posts 16+
Go to page: Previous  1, 2
marcel.d
1997 Volkswagen Golf
Post23-09-2008, 21:57    Subject: Quote
No, I didn't need to log in. Both STGs likely support WFS 2.
I have ultimately proceeded as follows:
First, I re-read and cleared the fault memory from the old ECU. Then, I removed the old ECU and installed the new one. I turned the ignition on and connected the laptop. Then, I went to WFS (25) in VAG-COM, first cleared the memory and then went to Adapt (10). I read, saved, and confirmed channel 00. Then, I cleared the fault memory in the new ECU and turned off the ignition for about 1 minute. The car then started immediately - so everything was done correctly icon_biggrin.gif
Now I'm driving with a fully functional STG and around 140 horsepower.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vacuum Regulator Issues: New Control Unit, Same Problem On-Board Diagnostics (OBD)
No new posts Injector Pump Control Unit Tuning/Adjustment On-Board Diagnostics (OBD)
No new posts Skoda Octavia RS: Adjust Steering Control Unit On-Board Diagnostics (OBD)
No new posts Timing Belt Replacement: New & Improved!;-) Diesel Engine Technology
