Diagnosis Interface
mozz
Post24-05-2002, 12:17    Subject: Diagnosis Interface Quote
Hello!
Hey, where can I actually get the connector for the diagnostic interface? Also, does it also fit on the serial port?
Hello everyone! The forum is really amazing!!
Rudi
Post24-05-2002, 13:13    Subject: Diagnosis Interface Quote
To connect the serial port of a PC to the diagnostic port, you first need an adapter (Jeff Noxon, the link should be on the left side).
I am also looking for an (affordable) alternative to the 16-pin diagnostic socket in the car icon_smile.gif
I believe it's the most efficient solution to tap into 3-4 lines and connect them to a sub-D connector that matches the pin configuration of the adapter.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Golf IV/Audi A4 Diagnostic Interface On-Board Diagnostics (OBD)
No new posts Interface for controlling the central locking system Electrical Systems, Vehicle Electronics, Multimedia
No new posts VAG-Com and Notebook without a Serial Port Diesel Engine Technology
No new posts Does the Passat TDI, MKB 1Z, have an OBD2 interface? On-Board Diagnostics (OBD)
