Webasto Telestart Receiver Plug
austrogolf
Post05-10-2008, 12:57    Subject: Webasto Telestart Receiver Plug Quote
hello,
"Just to start, I hope I've posted in the right sub-forum."
I am looking for the part number of the 6-pin connector used in Webasto FFB receivers/Telestart control units.
I would be grateful for any advice; unfortunately, I can't find this connector in the spare parts catalog at all (neither from Webasto nor from VAG).
You're welcome, Austrogolfer.
Translated on 16-10-2026, 1:52.
michiglaser
2007 Audi A4 Avant
austrogolf likes this.
Post05-10-2008, 17:12    Subject: Webasto Telestart Receiver Plug Quote
6Q0 972 706
That should be the correct number.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 16-10-2026, 1:53.
austrogolf
Post08-10-2008, 10:20    Subject: Webasto Telestart Receiver Plug Quote
hello,
Thank you for your very helpful answer.
Perhaps you could help me again: do you also have the part number for the corresponding crimp contacts for this connector?
You're welcome, austrogolfer.
michiglaser
2007 Audi A4 Avant
Post09-10-2008, 22:07    Subject: Webasto Telestart Receiver Plug Quote
Sure, 000 979 009 should be the repair cable with two connectors at both ends.
Perhaps it's also worth contacting Bosch or Webasto directly, although I had to pay a considerable amount for the connector plugs for my EasyStart from Eberspächer.
You'll probably end up paying less with VW.
Alternatively, you can simply open the casing and solder directly to the components inside.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 16-10-2026, 1:54.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Webasto T90 Receiver Wiring Diagram On-Board Diagnostics (OBD)
No new posts OBD2 Connector: Types, Uses & Benefits Diesel Engine Technology
This topic is locked, you cannot edit or reply. ODB Connector: Buy Online Now! On-Board Diagnostics (OBD)
No new posts 2. K-line at the connector On-Board Diagnostics (OBD)
