Hello everyone!
Here's a quick update on my renovation!
I've now wired everything up as much as possible and re-programmed the instrument cluster to the extent that I could.
Initially, I thought I wouldn't need a CAN connection between the MSG (Modular Signaling Device) and the instrument cluster, as my vehicle didn't have it before. However, I quickly realized that the WFS (Windshield Washer Fluid Sensor) also sends its signal to the MSG via this connection, so I installed those wires this morning.
If I try to start the engine now, it will briefly run and then shut off again.
The WFS (Wind Field Sensor) in the combination instrument is deactivated.
However, the MSG is still reporting an error, indicating that it is not receiving signals from the ABS control unit data bus and the transmission control unit data bus.
Unfortunately, I don't know what conditions must be met for MSG to not be blocked.
Okay, I'll provide the error messages now. I hope someone can clarify the situation.
First read after I connected everything:
VAG-COM Version: DRV 311.3-S
Control unit part number: 038 906 019 HM.
Component and/or version: 1.9L R4 EDC 0000AG 1601.
Encoding: 00001
Workshop code: WSC 02325.
Additional information: WAUZZZ4B43N110518 AUZ7Z0C2400661
5 error codes found:
18058 - Data bus drive, missing message from the instrument cluster.
P1650 - 35-10 - - - Intermittent.
17978 - Motor control unit locked.
P1570 - 35-00 - -
18057 - Data bus communication fault: No message received from the ABS control unit.
P1649 - 35-00 - -
18034 - Data bus malfunction: No message received from the transmission control unit.
P1626 - 35-00 - -
18043 - Data bus drive: Missing message from the climate control unit.
P1635 - 35-10 - - - Intermittent.
Control unit part number: 4B0 920 933 G.
Component and/or version: KOMBI+TRAVEL. VDO D12
Encoding: 00040
Workshop code: WSC 20599.
2 error codes found:
01177 - Engine Control Unit.
49-00 - No communication.
01304 - Radio
"Der schnelle braune Fuchs springt über den faulen Hund."
Second data read after establishing the CAN connection between the instrument cluster and the MSG (Modular Signaling Device).
Encoding: 00001
P1570 - 35-00 - -
P1649 - 35-00 - -
P1626 - 35-00 - -
17849 - Exhaust gas recirculation (EGR) valve
- Open circuit/Short to ground.
P1441 - 35-10 - - - Sporadically.
Encoding: 00040
"1 error found:"
01304 - Radio
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien. Die Blumen blühen in voller Pracht, und die Bäume spenden angenehmen Schatten. Es ist eine Zeit der Freude und des Glücks."
Reading out the ABS control unit, which does not contain a CAN bus.
Control unit part number: 8E0 614 111 B.
Component and/or version: ABS/EDS 5.3 FRONT D10.
Encoding: 0273004283
Workshop code: BB 24332.
No error code found.
