Hi Kurt,
Sure, I meant the standard VE4, not the VP37
The problem is the following:
Bought a WoMo:
Cold start is very poor, rough idling, slight blue smoke.
It worked better when it was warmer.
The KSB (fuel shut-off valve) doesn't seem to be working (it's receiving 12V but nothing is happening).
When operated manually, the adjuster works as needed.
We replaced the timing chain a few days ago.
Unfortunately, I didn't have a chance to test drive it beforehand...
After the timing belt replacement, the car felt a bit sluggish. It could only reach about 80% of its maximum speed.
It took him a lot of attempts and effort to finally reach the maximum speed.
Full power wasn't available either, as it always slowed down when going uphill.
We initially thought the wastegate might be stuck.
However, that was probably not the case. Afterwards, the boost pressure was measured.
And I've also driven it with the wastegate disabled.
No matter which 'mode' you choose, it's always the same game.
After that, adjust the pump to its maximum setting, and then later on, shift it back by about 6 degrees (it was initially set to its maximum early timing).
Lief sehr bescheiden. Sehr unruhig. Lots of smoke.
Danach um etwa 3° zurück verstellt (3° später). WieThat's crap.
Then, adjust the timing of the ESP by one tooth on the crankshaft (i.e., approximately 3 degrees earlier).
Absolutely nothing. The engine wouldn't even start.
Now I've reset the Z-R and set it to approximately 1 degree retarded.
It's running very well, but the performance still isn't quite there yet.
Sure, things would be easier with a measuring instrument.
Unfortunately, I don't own any of those myself...
And the turbocharger pressure thing is important to me.
'Firstly, I wanted to know the condition of the engine.'
and planned to increase the ESP voltage in the future.
and possibly increase the loan-to-deposit ratio (LDR).
'Cu Rod'
