Set the desired speed to 1400 RPM using the pedal while the vehicle is stationary, then depress the clutch.
-> Quickly increase the speed to over 2000 RPM.
However, this only works if he regenerates.
It seems someone made a mistake while adjusting the characteristic curves .
"Since I have DSG (dual-clutch transmission), I can't test the clutch behavior. However, with the A3 and software version 1185, something "interesting" happened during regeneration on the highway: If you gave it a lot of gas and then suddenly lifted off the accelerator, the engine RPM would briefly spike up by about 400 RPM."
At first, I thought the DZM was broken. But it only occurred during the regeneration phases, and it's no longer present with the 2968 software update.
Pete.
