I'm having a problem with my engine control unit (ECU) (Golf 3 TDI, year 1994, engine code 1Z).
He's showing me a low voltage reading on the dashboard, even though the battery and generator are working.
The battery shows 13.5 volts, but VAG-COM indicates 10.8 volts.
I've already replaced the control unit: now it's showing 12.2 volts.
I just want to check the power supply to the control unit.
The sockets 42 and 46 should be bypassed using auxiliary leads from V.A.G.
Can I simply bridge the connectors using test leads?
Does anyone have the exact pinout diagram for the 1Z connector?
Thank you in advance.
Adrian. Renault Espace 16V Bj. 2000 mit LPG
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 28-09-2026, 12:57.
