Hinweis an die T4- 2.5 TDI-Fahrer bis 2000>>Zahnriemen | Posts 16+
Go to page: Previous  1, 2
Octavia_4x4
Post15-01-2009, 15:42    Subject: Quote
"You're right, I read that yesterday while troubleshooting again in the T4 wiki... I really don't want to have to remove the speedometer."
"With this car, things always break. It's usually the nerves [referring to people's patience]. The automatic climate control went haywire and displayed completely wrong values for the outside temperature, so I wanted to replace the sensor. But on the way between the bumper connector and the temperature sensor, the wiring harness was broken in four places."
Okay, bumper removed, new wiring harness built, new connectors crimped on – at least it's working again now.
I'm going to try taking the speedometer out this weekend.
Translated on 21-08-2026, 12:23.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Possible tachometer tampering? On-Board Diagnostics (OBD)
No new posts Leak detection guide for the cooling system Diesel Engine Technology
No new posts Important note regarding the use of the VW 3099 for torqu... Diesel Engine Technology
No new posts K&N LF Drivers: Your Guide Diesel Engine Technology
