Holpriges Anspringen bei Temperaturen < 10° | Posts 16+
Go to page: Previous  1, 2
Bo Duke
Karma: +3 / -1   Thank you, like it!
Post15-01-2009, 17:45    Subject: Quote
Steffen W wrote:
There's a product like that from Beru. The exact name is: "Glow Plug Grease GKF01".
Do not overtighten, no more than 17 NM. Remember that.
Hi Steffen,
Okay, thank you very much.
Okay, please provide the German text you would like me to translate.
Translated on 14-09-2026, 12:48.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post15-01-2009, 22:16    Subject: Quote
How many degrees did you have last week, Bo?
We had temperatures of -15 degrees Celsius all week, and once it was -25 degrees Celsius in the morning. The Passat always started, although it required three pre-glow cycles and was very reluctant. After 20 kilometers, it even reached 90 degrees Celsius on the temperature gauge. This is truly my dad's best car.
The Sharan was hit harder. The auxiliary heater and its associated components failed. It wouldn't get warm at all, even after 50 km. The display always showed a low battery warning. And on that day with the extreme cold, the main battery also failed.
As it got warmer, the auxiliary heater turned back on. The next chance I get, I'll put in a ceramic igniter and a new flame arrestor screen. This *has* to work in the winter!
Passat Variant BGW 2005
Translated on 14-09-2026, 12:50.
Bo Duke
Post16-01-2009, 8:45    Subject: Quote
Wow, -25°C, that's quite a temperature! You're right, the comfort technology should work in those conditions; that's what it's there for.
The temperature at our place didn't drop below -10°. We still went ice skating, though icon_lol.gif.
Why does the multiple pre-glow function work? I thought it was already pre-glowed for a longer time than the display in the instrument cluster indicates.
Couldn't you simply wait longer after the light goes out and then turn the ignition back on (which would be gentler on the ignition switch)? It's not cold enough anymore for me to test that.
Translated on 14-09-2026, 12:51.
No new posts Air in Pipes: Troubleshooting Starting Problems Diesel Engine Technology
No new posts TDI: Blinking Glow Plug, Hard Starting Diesel Engine Technology
No new posts Cold Start Issues: Troubleshooting Engine Problems Diesel Engine Technology
No new posts Temperatures at LLK PQ 34 Upload
