Passat 3BG: Brake Light Switch & Engine Problem
grude4
Post20-01-2009, 9:30    Subject: Passat 3BG: Brake Light Switch & Engine Problem Quote
Hello! I have a Passat 3BG, manufactured in March 2005, with 101 hp and ESP. In my car, the "engine malfunction" warning light is on, and the yellow tachometer display is lit up with an exclamation mark.
I read the error memory, both in the engine and in the brake electronics.
The error code indicated a brake light switch malfunction that could not be cleared.
I then installed a new switch, but there's still no improvement. What else could it be?
The ABS is pulsating, and the brake booster is also partially functional even without it.
Have you ever encountered this error before?
Sincerely, Simic.
Translated on 10-10-2026, 7:20.
Post20-01-2009, 9:43    Subject: Passat 3BG: Brake Light Switch & Engine Problem Quote
Check the activation status of BOTH brake pedal sensors using VAG COM or a suitable diagnostic system.
When installing the switch, proceed carefully and follow the instructions, otherwise there is a risk of damaging it again.
Alternatively, check if the wrong bulb was accidentally installed in the taillight/brake light and make sure everything is working correctly in the rear.
Translated on 10-10-2026, 7:21.
grude4
Post20-01-2009, 9:46    Subject: Passat 3BG: Brake Light Switch & Engine Problem Quote
I have VAG-COM. How do I check the switches using VAG-COM? Which measuring block should I look in?
Sincerely, Simic.
Translated on 10-10-2026, 7:22.
grude4
Post20-01-2009, 10:12    Subject: Passat 3BG: Brake Light Switch & Engine Problem Quote
Hello! What about the blue clutch switch next to the brake light switch? What is it used for?
Sincerely, Simic.
servusssss
Karma: +12 / -0   Thank you, like it!
Steffen W likes this.
Post20-01-2009, 13:33    Subject: Passat 3BG: Brake Light Switch & Engine Problem Quote
Hello! What about the blue clutch switch next to the brake light switch? What is it for?
Sincerely, Simic
The system, for example, will disengage the cruise control if you press the clutch pedal.
As far as I know, this is also to protect the clutch (torque limitation).
Translated on 10-10-2026, 7:23.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 TDI: Overheat AC Switch? Diesel Engine Technology
No new posts Engine Error Message in Cold Weather - False Alarm? Diesel Engine Technology
No new posts Engine Problems? Workshop - No Error Codes Diesel Engine Technology
No new posts Backup fuse for trailer brake light. Electrical Systems, Vehicle Electronics, Multimedia
