christians Profi-Schrauber
09-02-2009, 12:36 Subject: |
jarobaldu wrote: |
The word itself, "laminar separation bubble," indicates the phenomenon: after 1 meter of hood length, there is no longer laminar flow. Therefore, there are no separation bubbles in that area.
Turbulent flow can also detach if the pressure gradient increases too rapidly; it is somewhat more tolerant of this than laminar flow. No airflow can follow the sharp angle at the rear of a station wagon or other vehicle with a steeply angled rear end.
jarobaldu wrote: |
After a few years of experimentation, I believe the following approach is worthwhile: First, simply measure. If you get positive results, then it's worth considering "why?"
It's still better to avoid completely pointless measurements. Measurements are too time-consuming to blindly check every conceivable scenario. Gruß Christian
Translated on 07-08-2026, 3:32.
09-02-2009, 20:26 Subject: |
Guys,
"Der Hucho" is a great book. It's going straight onto my wish list.
Thanks to Uni-Bib, I'm just browsing through and looking at the pictures for now.
I probably won't have time to read until I retire.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 07-08-2026, 3:33.
Profile PM Garage |
jarobaldu Profi-Schrauber
11-02-2009, 9:56 Subject: |
christians wrote: |
That's why the rear also gets a deflector spoiler; a vortex generator wouldn't be effective there.
christians wrote: |
It's still better to avoid completely pointless measurements. Measurements are too time-consuming to blindly check all conceivable configurations. |
And how else would you disprove such "inventions"?
I still believe that a simple approach with or without [something] is the best solution. Renault Espace 16V Bj. 2000 mit LPG
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 07-08-2026, 3:35.
11-02-2009, 10:15 Subject: |
Would you measure whether a sheet spread behind the stern reduces fuel consumption?
Some things can be calculated, or experience tells you that there's no need to measure any further.
Translated on 07-08-2026, 3:36.
Profile PM Garage |
11-02-2009, 11:25 Subject: |
Hi there,
before anyone here thinks that I believe in the Turbultor...
There's a lot of misleading information out there claiming to save fuel, but proper measurements can prove that it doesn't work. Some automotive magazines have already written about this.
I would suggest using the exact same approach for these "turbulators."
And I'm almost certain that the inventor would still find arguments as to why the measurement was unsuitable: the air pressure was too high, the color of the car was inappropriate, and the lunar phase was wrong...
Adrian.
P.S. What color should the bed sheet be?  Renault Espace 16V Bj. 2000 mit LPG
Translated on 07-08-2026, 3:37.
11-02-2009, 11:41 Subject: |
White and red, so that it is clearly visible when I throw it away towards the end of the measurement and it sticks to the windshield of the car in front  .
Translated on 07-08-2026, 3:38.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
11-02-2009, 21:28 Subject: |
*loud laugh* What a completely nonsensical thing to attach to the roof  . If someone forgets to remove it before driving into their (underground) garage, it will cause more harm than good! It's unbelievable that people still fall for this...  NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 07-08-2026, 3:39.
Profile PM Email Garage |
a dancer Blaumann
Joined: 09/07/2006 Posts: 55 Karma: +2 / -0 Location: Wertheim
13-02-2009, 16:11 Subject: |
After a quick glance, I believe that in the last link, the large rear wing and its airflow are more related to the vortex generator than simply reducing drag (cw).
It seems that it's not getting enough flow when the VG is missing.
Furthermore, they conducted their measurements at 180 km/h... the Peugeot from the "aforementioned inventor" cannot achieve that speed  .
And if so, the "Turbolator" has "imprinted" itself on the windshield of the vehicle behind.
Read the Hucho!!! Transparency, Teamwork
Translated on 07-08-2026, 3:41.
Profile PM Garage |
a dancer Blaumann
13-02-2009, 17:09 Subject: |
dieselmartin wrote: |
Furthermore, they made their measurements at 180 km/h... the Peugeot from the "aforementioned inventor" cannot achieve that speed  | .
Translated on 07-08-2026, 3:42.
17-02-2009, 16:42 Subject: |
Here's the ultra-short version of the 1000-page Hucho book.
http://media.automobilrevue.ch/files/93612_luftwiderstand.pdf
Profile PM Garage |
18-02-2009, 12:54 Subject: |
Again: On a car with a steeply sloping rear end, like the one in question, this effect wouldn't be noticeable. Also, even the rear window of a sedan would be too steep. If the car didn't have a limited width, vortices would form at the C-pillars, which would reduce or shift the stall point. Gruß Christian
Translated on 07-08-2026, 3:43.
