seiner meinung nach seine batterie zu stark belasten würde.
Hi Joerg,
I meant the case where both positive terminals of the amplifier are connected, so the amplifier is permanently on: 0.6 amps... that would be too much. The solution using a wire from the radio is already better than the option using the ignition switch.
____________
aaah, now it's working perfectly (even without ignition)... I overlooked this antenna connector while measuring, because there's no labeling on the VW side (connector) . Thanks again .
____________
