Coolant Flange Thread Repair G3 AFN
reuselkopp
Post02-03-2009, 16:11    Subject: Coolant Flange Thread Repair G3 AFN Quote
Hello everyone,
"Since my coolant flange (where the temperature sensor is located) is leaking, I want to fix it. About two years ago, I already replaced the seals at the same location, and when tightening the screws, I slightly overtightened one."
I think that if I disassemble the parts, the screw won't tighten properly anymore, so I wanted to insert a threaded sleeve there. Now, here's my question:
What size screw is actually used there? I think it's a 6mm screw, but I'm not sure. Does anyone have any of these threaded sleeves lying around that they could sell me for a small price? I don't want to buy a whole set because I probably only need one.
"Thank you!"
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 10-08-2026, 15:56.
reuselkopp
Post03-03-2009, 9:06    Subject: Coolant Flange Thread Repair G3 AFN Quote
Gemosche.
Can anyone tell me anything about that icon_cry.gif?
Greetings.
Reuselkopp.
Translated on 27-08-2026, 2:50.
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post04-03-2009, 13:39    Subject: Coolant Flange Thread Repair G3 AFN Quote
Some workshops use "Helicoil" (or something similar) in such cases.
The flange has screws with a size of M6 x something.
http://www.pfeffer.ch/helicoil.htm
However, I would still try it. If that doesn't work, I would suggest visiting a few workshops (trucks, agricultural machinery, cars) and asking if they can lend you one.
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post04-03-2009, 14:15    Subject: Coolant Flange Thread Repair G3 AFN Quote
I always borrow the thread repair kit from the local engine rebuilder. It's not a Helicoil, but rather "real" thread inserts, with an outer diameter of about 7-8mm and an inner diameter of M6.
Translated on 27-08-2026, 2:51.
No new posts Thread Repair: Helicoil vs. Time Sert Transmission, Chassis, Body & Interior
