DPF in Ordnung? | Posts 16+
Go to page: Previous  1, 2
Benni
Post02-04-2009, 9:05    Subject: Quote
The problem, and it's the same with the Passat, is that the amount of ash produced is calculated based on the consumption of additives (?) and fuel (?).
If it were measured, there would be fewer problems; however, to achieve this, the car would also need to be told, "Hey, you have a new filter installed, please calibrate yourself."
At VW, we have the advantage of using VCDS and can reset this ourselves. I suspect that you don't have something like that available to you.
In addition, the electronic equipment at Citroën workshops (the ones I know) is more than just basic; I think the people working there probably follow instructions strictly out of fear of damaging something.
Translated on 19-07-2026, 22:00.
C5Kuhli
Post03-04-2009, 10:00    Subject: Quote
Of course, it would be possible to make all the electronics much more intelligent.
But who wants that? It's all geared towards customer-workshop relationships, and therefore designed for exploitation. And this is just the beginning... icon_mad.gif
These days, if you can still change your light bulbs yourself without having to disassemble half the car, you're already doing pretty well!
Citroen C5 110 FAP Bj.01.05 1,6 Liter 109 PS
Translated on 19-07-2026, 22:01.
No new posts Engine Mounts: Are They Still Good? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Engine Misfire? Next Drive is Fine Diesel Engine Technology
