Axle Nut Torque: Specs & Installation Guide
Tribu
Karma: +3 / -2   Thank you, like it!
Post19-03-2009, 23:03    Subject: Axle Nut Torque: Specs & Installation Guide Quote
Hi...
- GOLF IV
How do you tighten the axle nut correctly without a torque wrench?
300 nautical miles, then turn 180 degrees, then another 50 nautical miles.
But what is this mess? Why make it so complicated?
Even if I were to buy a torque wrench now, wouldn't 50 Nm be a joke for an axle nut, or do you not think so?
Translated on 13-08-2026, 18:24.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post20-03-2009, 0:00    Subject: Axle Nut Torque: Specs & Installation Guide Quote
Well, that makes sense.
Let's start with a deposit of 300 million.
Then turn it up.
Then, with moderate preload, tighten to 50 Nm. This depends on the designed bearing clearance. Others are tightened very securely.
Opel Vivaro, rear axle, tightening torque: 240 Nm.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 13-08-2026, 18:25.
Tribu
Post20-03-2009, 0:05    Subject: Axle Nut Torque: Specs & Installation Guide Quote
Thank you for the clarification.
Well then, I guess I'll go buy one of those torque wrenches icon_biggrin.gif; I have to...
Translated on 13-08-2026, 18:26.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post30-03-2009, 18:41    Subject: Axle Nut Torque: Specs & Installation Guide Quote
What year is the Golf 4? What engine and transmission does it have?
Normally, but...
Vehicles with twelve-point bolt heads.
- Tighten the hexagonal nut with 200 Nm and loosen it by half a turn.
- Rotate the wheel hub by 180 degrees.
Subsequently, again with...
Tighten an additional 50 Nm and then rotate a further 60 degrees.
B.Eng (FH) u. KFZ Meister
Translated on 13-08-2026, 18:27.
Tribu
Post30-03-2009, 21:18    Subject: Axle Nut Torque: Specs & Installation Guide Quote
Thank you for the information, but everything has already happened. A kind member sent me the correct suit details via private message. Everything worked out icon_biggrin.gif.
Thank you very much nevertheless...
Translated on 13-08-2026, 18:29.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post30-03-2009, 21:27    Subject: Axle Nut Torque: Specs & Installation Guide Quote
And what is correct?
Tribu
Post30-03-2009, 22:05    Subject: Axle Nut Torque: Specs & Installation Guide Quote
That was for my car...
Tighten to 300 Nm.
Rotate 180 degrees.
Retighten with 50 Nm of torque.
Rotate 45 degrees further.
Translated on 13-08-2026, 18:30.
4cheers
Post03-04-2009, 21:00    Subject: Axle Nut Torque: Specs & Installation Guide Quote
The Steffarn version is for models with a 12-point nut. Could the other one be for the version with an Allen screw?
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post04-04-2009, 9:05    Subject: Axle Nut Torque: Specs & Installation Guide Quote
Yes, the screws are tightened with different torque values than the nuts.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Torque Diesel Engine Technology
No new posts Torque AJM 6-G Diesel Engine Technology
No new posts Torque Myths: Debunking Common Misconceptions Diesel Engine Technology
No new posts Torque 1.6 TD JR - Unsatisfactory Diesel Engine Technology
