AJM startup problem
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
cliff
Post05-04-2009, 22:42    Subject: AJM startup problem Quote
Hello.
I'm having the following problem with my Volkswagen Golf IV, manufactured in 2001, engine code AJM.
It often happens that the glow plug in the engine either doesn't turn on at all, or only turns on after a very long time (even when it's warm). Then, when starting, the engine immediately revs up to around 2,000-3,000 RPM, pulsating twice. After that, either the idle speed is normal, or it's around 1,100 RPM (and this isn't temperature-dependent).
Furthermore, it can also happen that when you are driving and stop at a traffic light, the idle speed suddenly increases to around 1100 RPM.
Unfortunately, there are no error codes stored in the system's memory.
Okay, so the question is: what's causing this?
Mathias
Translated on 17-07-2026, 22:45.
Klausel
Post05-04-2009, 23:57    Subject: AJM startup problem Quote
You have a VAG-COM device, right?
Take a look at the temperature of... (e.g., in MWB 1).
Kühlwasser an, ob da plausible Werte kommen. Otherwise,
replace the temperature sensor.
Best regards, Klaus.
Translated on 17-07-2026, 22:46.
cliff
Post06-04-2009, 13:31    Subject: AJM startup problem Quote
Hello.
Today, I encountered the same problem again and checked the error memory once more. This time, it indicates "G62 temperature sensor."
I exchanged it today as well, and I hope that solves the problem.
Mathias
Translated on 17-07-2026, 22:47.
No new posts Startproblem BMW 525 tds Diesel Engine Technology
This topic is locked, you cannot edit or reply. Starting problem VW Golf 3bg 1.9 PD AVF Diesel Engine Technology
No new posts Startproblem 2,5 V6 TDI Diesel Engine Technology
No new posts Start problem TDI MKB:1Z Diesel Engine Technology
