Passat 3B: Weak AFN Engine - Troubleshooting
mserge
Post20-04-2009, 18:05    Subject: Passat 3B: Weak AFN Engine - Troubleshooting Quote
Hallo, der Passat eines Kollegen ist ziemlich schlapp. ich habe dann einige Messwertblöcke gescheckt (Siehe Anhang) doch konnte ich nur herausfinden dass bei weniger als 2200 U/min zu wenig Ladedruck anluiegt und somit die Luftmasse zu gering ist. But why?
The engine runs smoothly (checked with a diagnostic tool). It feels like a 16V gasoline engine; below 2500 RPM, there's almost no power, then it starts to pick up and stays at that level until around 4000 RPM, where it either reaches its rev limiter or becomes undrivable. It lacks the typical TDI effect. At first, I thought it might be the mass airflow sensor (MAF), but since its readings are up to 950, I believe it's working correctly.
Could someone perhaps analyze the logs and point out something I might have missed?
Thank you very much.
passat afn log 3-8-11.xls
 File name:  passat afn log 3-8-11.xls
 File size:  21.5 KB
 Downloaded:  442 times
passat afn log 1-3-10.xls
 File name:  passat afn log 1-3-10.xls
 File size:  41.5 KB
 Downloaded:  540 times
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 12-08-2026, 15:54.
Boro
Post23-04-2009, 14:52    Subject: Passat 3B: Weak AFN Engine - Troubleshooting Quote
Have you ever cleaned LMM with brake cleaner? It often works wonders icon_biggrin.gif.
Translated on 12-08-2026, 15:55.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts 3.0 tdi im A5 untenrum schlapp? Diesel Engine Technology
No new posts BMR feels sluggish again Diesel Engine Technology
No new posts TDI Smoking? Get Help Now! Diesel Engine Technology
No new posts Tried the PD-Powerbox -> performance gain is quite min... Diesel Engine Technology
