TDI Injectors: 2.7L & 3.0L V6 Engines
christians
Post30-04-2009, 12:56    Subject: TDI Injectors: 2.7L & 3.0L V6 Engines Quote
"Elsewhere, I have often read about faulty injectors in V6 TDI engines. Specifically, those manufactured up to approximately x/2006 are said to be affected. Apparently, a coating is coming loose, which results in the injectors no longer sealing properly."
Does anyone know anything about this?
Is it possible and worthwhile to only replace the nozzles in order to limit costs?
Gruß Christian
Translated on 25-07-2026, 4:55.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-SG: Why Only 6 Injectors? Diesel Engine Technology
No new posts Injector Problems: Common Issues & Solutions Diesel Engine Technology
No new posts Injector Overhaul: Repair or Replace? Diesel Engine Technology
No new posts Injector Calibration: How to Calibrate Injectors Diesel Engine Technology
