VW LTII Diagnosis: Troubleshooting & Repair
xxjopa
Post10-05-2009, 18:25    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Hello!
I have a VW Passat 3B and an LTII. I can easily connect to my Passat using my diagnostic adapter and RossTech software, but what do I do with the LTII? It has the Mercedes-style connector, the round 14-pin one.
Can I build my own adapter for that? But how will that work with my diagnostic adapter?
Thank you and best regards,
Jonathan.
Translated on 24-08-2026, 22:32.
Post10-05-2009, 19:03    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Take a look at the pinout:
http://shop.dieselschrauber.de/product_info.php/cPath/25/products_id/51
If it's a current-model Sprinter van, then things look bad because it's 100% Mercedes.
Translated on 24-08-2026, 22:33.
xxjopa
Post10-05-2009, 19:15    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Yes, that might work. My connector looks like this. But how do I know if it will function with the RossTech software, and then also with my hardware?
Jonathan.
Post11-05-2009, 7:43    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Welche Typenbezeichnugn hat Dein Sprinter genau? Year of construction?
Translated on 24-08-2026, 22:34.
xxjopa
Post11-05-2009, 13:14    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Is this a Volkswagen LTII from the year 2001 with a 2.5 TDI engine and ANJ code?
So, not a sprinter...
Jonathan.
Post11-05-2009, 13:24    Subject: VW LTII Diagnosis: Troubleshooting & Repair Quote
Then it works, of course...
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts Diagnosis On-Board Diagnostics (OBD)
No new posts KKL/KL Diagnosis: Causes & Treatment Diesel Engine Technology
No new posts VAG Diagnostics: Troubleshooting & Repair On-Board Diagnostics (OBD)
