A4 AHU: Vacuum Pipe Differential Interruption
barborossa
Post15-07-2009, 19:00    Subject: A4 AHU: Vacuum Pipe Differential Interruption Quote
My Audi A4 (year 1997) with the AHU engine repeatedly goes into limp mode when I let it coast.
The error code in the diagnostic log indicated a "broken intake manifold pressure differential." A log file was also created.
"The VTG (Variable Turbine Geometry) isn't sticking and can be moved freely. The hoses on the solenoid valve were replaced, and then another test drive of 20 km was performed. Interestingly, the error didn't reappear. In previous test drives, the error occurred after just a few hundred meters."
LMM was updated last week.
Maybe someone would be willing to take a look at my log file.
http://www.fileuploadx.de/195735
Translated on 24-08-2026, 22:38.
Post15-07-2009, 19:46    Subject: A4 AHU: Vacuum Pipe Differential Interruption Quote
The log does not correspond to the environmental conditions that we typically use here. Please read the technical article on log generation for more information!
Despite everything, it's quite noticeable that the boost pressure already deviates from the target by approximately 300 mbar even at low load.
Something is definitely wrong here. Please read the relevant technical articles and work through the points mentioned regarding boost pressure problems (e.g., leak in the boost pressure system, vacuum control, actuator test/basic adjustment).
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 24-08-2026, 22:40.
blackblizzard
Post20-07-2009, 11:18    Subject: A4 AHU: Vacuum Pipe Differential Interruption Quote
"In my case, it was the hose between the intake manifold and the control unit."
vwSchrauber
Post20-07-2009, 13:09    Subject: A4 AHU: Vacuum Pipe Differential Interruption Quote
An AHU does not have a VTG (Variable Turbine Geometry) but instead uses a wastegate turbocharger - Garrett T15 icon_exclaim.gif.
Translated on 24-08-2026, 22:41.
barborossa
Post22-07-2009, 23:02    Subject: A4 AHU: Vacuum Pipe Differential Interruption Quote
Bugs fixed.
The intercooler piping had a leak. The connecting hose to the turbocharger was torn underneath. Thank you again to everyone.
No new posts Document A6 4B, Fresh Air Blower Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Intake Manifold: Large & High Performance Diesel Engine Technology
No new posts Carbon Buildup in 2.5 TDI Intake Manifold (BDG, EU4) Diesel Engine Technology
No new posts AGR Valve for 038 Engines Diesel Engine Technology
No new posts Intake Manifold Bracket Broken (1Z, AHU, AFN, ALE) Diesel Engine Technology
