Fuel Injection Pump
phil1603
Post10-08-2009, 21:19    Subject: Fuel Injection Pump Quote
Hello everyone, I'm new here, but I've been a fan of this helpful website for quite some time.
I have a question.
Ich fahre einen Ford Galaxy 1,9 TDI 90 PS Motor kz. AHU.
"Because the car has been starting increasingly poorly for weeks, I took a closer look yesterday and discovered that the fuel injection pump (Bosch) is leaking."
- EDIT by mod: Image attached.
I've marked the spot. Could this leak be the reason why the engine is hard to start?
I've also noticed that the fuel in the transparent hose is slowly flowing back towards the diesel filter.
I'm feeling nauseous because I'm having a stomach issue, and I'm hoping that the procedure tomorrow will fix it.
Best,
Phil
 Fuel Injection Pump
 File size:  50.84 KB
 Viewed:  6621 times
Translated on 23-10-2026, 3:11.
Post10-08-2009, 21:47    Subject: Fuel Injection Pump Quote
Please check the following:
- Compression
- Injection timing.
- Check nozzles.
- KW wheel (searching for "1Z KW wheel" will help you find it).
Translated on 23-10-2026, 3:12.
phil1603
Post11-08-2009, 18:52    Subject: Fuel Injection Pump Quote
Hey everyone, as I mentioned, I had the fuel injection pump sealed today. It cost me €117. I put everything back together, and lo and behold! It started right up, no air bubbles, no sputtering!
"lg" is an abbreviation for "liebe Grüße," which means "best regards" or "love." It is often used in emails and letters to express affection or friendship.
Here is an example of how "lg" might be used in a sentence:
"I hope you are doing well. lg, [Your Name]"
In this example, "lg" is used to express affection and friendship. It is a way of saying "I care about you" or "I am thinking of you."
Translated on 23-10-2026, 3:14.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 Injection Pump Diesel Engine Technology
No new posts CAV Injection Pump Diesel Engine Technology
No new posts Fuel Injector AFN Diesel Engine Technology
No new posts SDI Fuel Injector: Performance & Reliability On-Board Diagnostics (OBD)
