bartheho Blaumann
Joined: 01/13/2007 Posts: 63 Karma: +2 / -0 Location: Michendorf bei Berlin
13-08-2009, 21:26 Subject: Passat Idle Problem: AVB Engine Fix |
I hope for your help.
Our family car has been making an uneven idling sound since early this morning, and it's a mystery to me.
- Year of manufacture: 2005, mileage: approximately 40,000 km, no chip tuning or modifications.
- No error codes found in the fault memory.
"When the engine idles for a longer period, the uneven running becomes much more noticeable. I've checked the intercooler, as far as I could with a cable lamp outside, and haven't found anything. What I did notice was a kind of oil sludge, or something similar, a black, viscous goo, which I found at the separation point between the engine and the transmission, in the direction of view below the oil filter. It's a very thick, dark black substance, which is unusual for an otherwise clean engine. As I mentioned, it's located between the oil filter and the fuel filter, in the direction of the transmission."
I once tried to take a picture of it, and I hope I can upload it...
I am grateful for any suggestions.
Best regards, Holger.
| Description: |
| File size: |
51.93 KB |
| Viewed: |
5416 times |
Passat Bj. 2014, MKB CAYC
Translated on 28-09-2026, 3:04.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
13-08-2009, 21:35 Subject: Passat Idle Problem: AVB Engine Fix |
I would say it's a disgusting bird. It's just DISGUSTING  .
Wash your car sometime and don't drive so fast.
If it came out from under the clutch bell housing, it's likely the dual-mass flywheel (DMF) friction material. -> A faulty DMF is the cause of the jerking.
Translated on 28-09-2026, 3:06.
Profile PM WWW Garage |
bartheho Blaumann
13-08-2009, 21:37 Subject: Passat Idle Problem: AVB Engine Fix |
Hello Reiner,
No, it's a type of oily sludge, almost like graphite...
13-08-2009, 21:38 Subject: Passat Idle Problem: AVB Engine Fix |
It was just meant to be funny. I've edited my post above.
Translated on 28-09-2026, 3:07.
bartheho Blaumann
13-08-2009, 21:50 Subject: Passat Idle Problem: AVB Engine Fix |
Sorry, but I was expecting this, and I'm a bit annoyed. I'm going to visit a friend tomorrow who runs a good independent garage, and I'll let you know what he says.
Does VW still offer goodwill guarantees for vehicles manufactured in 2005?
bartheho Blaumann
14-08-2009, 9:06 Subject: SEO: Best Practices for Keyword Ranking |
I went to VW, and they confirmed the diagnosis. VW will cover 50% of the material and labor costs.
Translated on 28-09-2026, 3:08.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
14-08-2009, 13:59 Subject: Passat Idle Problem: AVB Engine Fix |
I honestly wouldn't have expected that kind of response and sense of responsibility from those men! Let's raise a glass together and celebrate properly! It doesn't happen every day that you get a pleasant surprise.
Glad to hear it, bartheho.
bartheho Blaumann
14-08-2009, 21:29 Subject: Passat Idle Problem: AVB Engine Fix |
Translated on 28-09-2026, 3:09.
