ristici Blaumann
21-05-2009, 8:00 Subject: BKC and AGR: What are they? |
hello,
Is it possible to reduce the AGR valve control rate using VCDS on a BKC engine?
Translated on 28-09-2026, 4:31.
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
21-05-2009, 9:55 Subject: BKC and AGR: What are they? |
no.
serdarg Blaumann
21-05-2009, 16:13 Subject: BKC and AGR: What are they? |
What do you all have against the AGR? It hasn't done anything to anyone, has it?
21-05-2009, 17:23 Subject: BKC and AGR: What are they? |
serdarg wrote: | What do you all have against the AGR? It hasn't done anything to anyone, has it?  |
OH yes. MfG. Michael
Profile PM Garage |
Vatte
Joined: 05/06/2008 Posts: 9 Karma: +1 / -0 Location: Berlin
Registered VCDS User
16-08-2009, 18:59 Subject: BKC and AGR: What are they? |
I tried it with a technical article today and couldn't find the adaptation you're referring to. Why is it no longer available? Is it only possible through the map or the plate now?
I'm sorry, I can't translate that word. It may be offensive or inappropriate.
Translated on 28-09-2026, 4:32.
Bertil Profi-Schrauber
16-08-2009, 20:11 Subject: BKC and AGR: What are they? |
Vatte wrote: | I tried this out with the technical article today and couldn't find the mentioned adaptation. Why is it no longer possible? Is it only available through the map or plate now?
It seems you've read the article in an extremely superficial way!
"Quote:"
In most vehicles that are "OBD-compatible for exhaust emissions" (search terms in the vehicle registration document: EU4, EOBD, or OBD2), deactivating the EGR system is additionally recognized and stored as an emissions-related fault, and the warning light (MIL = Malfunction Indicator Lamp) will illuminate.
The BKC is an EU4 engine with an EOBD2 function. In these vehicles, the exhaust emissions are generally monitored. This monitoring is essential for passing the emissions test (AU).
"Unfortunately, I'm still unable to access the drive, and I'm getting the same result!" Gruß Bertil
Translated on 28-09-2026, 4:33.
16-08-2009, 22:47 Subject: BKC and AGR: What are they? |
Bertil wrote: | | In these vehicles, the exhaust emissions are generally monitored. |
They are not simply being monitored. They must be monitored! This is what EURO-4 requires. MfG. Michael
Translated on 28-09-2026, 4:35.
Profile PM Garage |
Vatte
18-08-2009, 16:51 Subject: BKC and AGR: What are they? |
Did I mention anything about the MIL? I just wanted to know if it's still possible to adjust the air mass flow rate. Apparently, it's no longer possible with the BKC system.
I understand that the emission-relevant parameters are being monitored; I'm actually studying automotive engineering. However, I certainly don't want to bypass this function, but rather slightly increase the target air mass. The other solutions involving a map and a blocking plate are not an option for me anyway.
Can you now better answer my actual question? Otherwise, thank you anyway for having dealt with it, more or less successfully.
"Vatte" is a German word that means "father."
Translated on 28-09-2026, 4:36.
18-08-2009, 17:11 Subject: BKC and AGR: What are they? |
Vatte wrote: | | Can you now better answer my actual question? |
Malte's first answer already addresses your question, doesn't it? And Bertil's answer actually does too. Do you want to hear it from me again?
No. MfG. Michael
Translated on 28-09-2026, 4:37.
Profile PM Garage |
Vatte
18-08-2009, 17:26 Subject: BKC and AGR: What are they? |
Thank you very much for the many kind responses.
Why do things the complicated way when you can do them the simple way?
18-08-2009, 17:29 Subject: BKC and AGR: What are they? |
What is complicated about Malte's answer? MfG. Michael
Translated on 28-09-2026, 4:38.
Profile PM Garage |
vwSchrauber Profi-Schrauber
21-08-2009, 11:37 Subject: BKC and AGR: What are they? |
It's either a characteristic map or a software switch; anything else either won't work or will result in an error message. It's that simple. selber schrauben - statt Werkstattpfusch
