davidshoes Blaumann
Joined: 06/10/2002 Posts: 155 Karma: +6 / -2 Location: Sachsen
20-04-2003, 20:23 Subject: T4 is going out... |
Our T4 TDI 111kW sometimes cuts out while driving at high speeds (over 160km/h) and restarts after a few hundred meters or so, usually after 10-30 seconds. This often happens when the tank is only about 1/4 full. What could be the cause? Is the diesel foaming so much that it can no longer be sucked in? As I said, everything will be fine again afterwards.
Andy Guest
26-04-2003, 23:47 Subject: Error memory...? |
and what then is in the error memory...?
Hello
Andy
davidshoes Blaumann
28-04-2003, 11:56 Subject: T4 is going out... |
Unfortunately, nothing! And the workshop has no plan!
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
28-04-2003, 12:27 Subject: T4 is going out... |
without further consideration, it sounds very much like relay 109 (motor management power supply)...
I don't know if it's even installed in your model.
If you find a relay plate with a '109 - Made in Tunesia' label, that's a likely candidate.
Hello, Rainer
Profile PM WWW Garage |
davidshoes Blaumann
30-04-2003, 17:48 Subject: T4 is going out... |
The relay has been replaced twice already, but without success...
maniac Guest
30-04-2003, 17:56 Subject: T4 is going out... |
Did you definitely take a long, sharp right-hand turn before each time?
is a common problem with the T4. It sucks in air.
either fill up the tank or take your foot off the gas in the (sharp) turn.
davidshoes Blaumann
01-05-2003, 11:57 Subject: T4 is going out... |
@ Maniac: So, wie ich erwartet habe, er saugt also Luft. Never drive with less than 1/4 of a full tank.
maniac Guest
01-05-2003, 20:19 Subject: T4 is going out... |
it's enough to make the gas pedal easier to use in such situations (empty tank and long curve). not digital gas.
I always drive until the light turns red. No problems.
