Throttle Body Actuator Motor (V157)
servusssss
Post29-08-2009, 14:24    Subject: Throttle Body Actuator Motor (V157) Quote
Hello fellow DIY enthusiasts,
I had this error message on a 2.0 TDI with 72,000 km (approximately 45,000 miles), manufactured in 2005, engine code BKD, and 4Motion drive.
"Die Sonne scheint hell und der Himmel ist blau."
The sun is shining brightly and the sky is blue.
Address 01: Engine
Control unit part number: 03G 906 016 AQ
Component and/or version: R4 2.0L EDC G000SG 7000.
Encoding: 0000172
Company number: WSC 01279
"One error found:"
19559 - Throttle valve motor (V157): defective.
P3103 - 000 - -
Environmental conditions:
Speed: 756 RPM.
Torque: 40.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 12.69 V
Binary value: 00101100
Torque: 150.0 Nm
Torque: 0.0 Nm
Besides the error message, there was also a significant jerking or shuddering when turning off the engine.
After replacing the valve, everything is working again.
Part number of the old one is 038 128 063 G, the new one is 038 128 063 L. It costs icon_smile.gif €389!
Since the thing is so cheap, I took the old one apart.
"The gearbox has two gears with broken teeth. The sensor that indicates the position of the flap is also broken."
In addition, the entire housing, including the electronics and gears, was filled with oil!
Here's my question: Is it normal for the housing to be filled with oil that smells like exhaust fumes? Or did the oil get into the housing through the axle bearings?
I've uploaded a few photos to the upload section.
[Link to the photos:]
"Chri" - This could be a shortened form of a name like "Christian" or "Christine." Without more context, it's difficult to say for sure.
Translated on 14-08-2026, 18:35.
vagtuning
Post29-08-2009, 14:33    Subject: Throttle Body Actuator Motor (V157) Quote
The new ones should last longer, as the old oil tanks were (wave-mounted).
It's something that's already well-known, so it's not really surprising. icon_wink.gif
Send pictures.
Translated on 14-08-2026, 18:41.
servusssss
Post29-08-2009, 14:48    Subject: Throttle Body Actuator Motor (V157) Quote
Hello vagtuning,
Thank you for your reply!
Yes, if that's cold coffee, then it should be perfect now.
Best regards, Chri.
Translated on 14-08-2026, 18:42.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post29-08-2009, 20:27    Subject: Throttle Body Actuator Motor (V157) Quote
Hi Chri, the price is terrible, my condolences icon_eek.gif.
Thank you for the pictures.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Motor (V157) - Photos Upload
No new posts AGR Valve: Engine Stall When Deactivated Diesel Engine Technology
No new posts Error code P2015 Intake manifold flap | VW CADDY III BLS ... Diesel Engine Technology
No new posts Rename V157 J338 Diesel Engine Technology
