Spare Parts Issues: A Critical Analysis
Muss man grobe Abweichungen bei "nicht-original-Teilen" hinnehmen??
ja, wieso sonst sind die Teile billiger
11%
 11%  [ 1 ]
keinesfalls, sind ja für das jeweilige Fahrzeug ausgelegt und müssen passen
77%
 77%  [ 7 ]
ich kauf eh nur Original-Teile
11%
 11%  [ 1 ]
Total votes : 9
Golfdriver
Post05-05-2003, 18:04    Subject: Spare Parts Issues: A Critical Analysis Quote
So, I'm curious (due to a specific situation) whether we have to accept that 'non-original replacement parts' sometimes differ significantly from the original parts, even though they are intended for a particular vehicle!
So, I ended up slashing my tires because, stupidly, I didn't immediately realize that the replacement fender was over 1cm narrower than the original!!! And you probably know how much of a difference that can make!!!
So, my tires no longer fit properly, and then it happened when I hit the first pothole! Thankfully, I noticed it before anything worse happened!
Hello.
Translated on 27-10-2026, 7:42.
christians
Post05-05-2003, 19:38    Subject: Spare Parts Issues: Solutions & Troubleshooting Quote
Yes.
The repair patches that used to be available for welding over were just as bad: thin, soft, poorly fitting, and "drawn" with unsightly creases.
Unfortunately, I haven't had good experiences with aftermarket brake pads on my C4 either.
Gruß Christian
Translated on 27-10-2026, 7:44.
