Turbo Problems Audi A2 1.4 TDI - Intermittent Issues
bernie123
Post19-09-2009, 20:15    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
Hello forum,
I'm looking for a checklist that can help narrow down the problem mentioned above.
Thank you in advance.
bernie
Translated on 04-09-2026, 8:02.
Post19-09-2009, 23:54    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
Point 1: Acquire a VAG-COM device.
Point 2: Read error codes.
Point 3: Post error messages here.
Without that, there are a thousand possibilities for what it could be. You need to have a general idea of the direction it's heading in.
Post20-09-2009, 12:06    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
... and please specify the engine code or at least the power output, as different turbochargers are installed.
Also, whether the car has been modified or not, and exactly when the problem occurs.
Translated on 04-09-2026, 8:03.
bernie123
Post20-09-2009, 12:20    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
Hello everyone,
So, the MKB is essentially the AMF without any modifications or tuning.
I'm currently checking under the car, more information will follow.
hello
there's bernie.
Translated on 04-09-2026, 8:04.
Post21-09-2009, 11:08    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
So, wastegate turbocharger.
How do you _know_ it's the turbo?
What about this option?
The mass airflow sensor is fluctuating, reporting insufficient airflow, which is causing the fuel injection quantity to be reduced via the opacity lookup table.
Post21-09-2009, 13:11    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
"Haha, our A2 used to have that problem too... although it was a persistent issue until I could find a parking spot. It ripped the clamp off the LD hose right at the turbocharger. The remains were completely rusted. It was a great defect, happening right in the middle of the night in the middle of nowhere... *yes, praise be, the beloved A2, it was a great car*."
Translated on 04-09-2026, 8:05.
bernie123
Post21-09-2009, 20:51    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
Okay, so I checked the clamps and hoses, and the intake on the turbocharger is a bit oily, which might be coming from the valve cover gasket. I'll get the error codes read.
Somewhat off-topic: Is it possible to deactivate the EGR system when using an AMF (Abgasmanagement-Filter)?
"Bernie asks."
Translated on 04-09-2026, 8:06.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post21-09-2009, 21:29    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
@martin: LMM kommt eher nicht direkt in Frage. Der wird nur zur Steuerung der AGR verwendet. Thankfully!
But the rest is correct. First, read the error codes, then proceed.
Yes, AGR can be put on hold. If there's no MIL, it's possible.
Translated on 04-09-2026, 8:07.
durnesss
Post25-09-2009, 13:31    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
It's not uncommon in the A2 category; check out the A2 forum.
Most often, it's a loose or cracked hose in the compressed air system.
Then an error: 'Rule limit exceeded, temporarily.'
It must be stored in the MSG.
It then goes into emergency mode with very little power, and the maximum speed is approximately 110 km/h.
After the restart, everything seems to be working fine again.
Until more than ~5 seconds of power is required, it reverts to emergency mode.
Friendly people often enjoy playing games like 'Werewolf' or engaging in activities where they exchange items.
which is somehow related to the boost pressure control system.
Thomas.
Translated on 04-09-2026, 8:08.
Diesel_Rudi
Post28-09-2009, 19:17    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
I suspect that the nitrite coating on the guide vane assembly is worn out. This often causes problems. Cleaning the exhaust side only provides temporary relief. Therefore, the best solution is either a good used part or a new one.
Regards!
Translated on 04-09-2026, 8:09.
brezelmann01
Post28-09-2009, 19:36    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
The AMF turbocharger uses a wastegate system, as mentioned above. So, it's not a variable geometry turbo (VTG).
Translated on 04-09-2026, 8:10.
Diesel_Rudi
Post28-09-2009, 19:58    Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Quote
He's right. I just checked on eBay. Sorry.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Jerky Acceleration: Troubleshooting & Fixes Diesel Engine Technology
No new posts Automatic Transmission Noises: Causes & Solutions Diesel Engine Technology
No new posts Brief interruption at AJM Diesel Engine Technology
No new posts Kurzer Aussetzer beim AHF Diesel Engine Technology
