Turbo Lag: The Extreme Guide
wacken
Post04-05-2003, 16:27    Subject: Turbo Lag: The Extreme Guide Quote
Hello, I've experienced this problem for the second time today. After washing my car (Audi A4, new model, 1.9 TDI-PD, 130 hp) at a self-service car wash and trying to drive away, I experienced extreme turbo lag every time I accelerated, regardless of the gear or speed. For the first 1-2 seconds, almost nothing happens when I press the accelerator, and then it accelerates normally. After turning off the engine and restarting it, the problem disappeared. The first time it happened, it was the same (although I don't remember if I had washed the car at that time, maybe it's related). Does anyone know what this could be?
Translated on 27-10-2026, 5:52.
Post04-05-2003, 20:47    Subject: Turbo Lag: Extreme Issues and Solutions Quote
wacken wrote:
For the first 1-2 seconds after pressing the accelerator, almost nothing happens, then it accelerates normally. After I turned off the engine and restarted it, the problem was gone.
Hi.
That also reminds me of my time with the VTG, although the "limp mode" periods were quite inconsistent there, sometimes lasting for several minutes after the start.
Translated on 27-10-2026, 5:53.
wacken
Post06-05-2003, 13:50    Subject: Turbo Lag: The Extreme Guide Quote
But we have already made those common icon_cry.gif.
zzzZZ
Post06-05-2003, 13:57    Subject: Turbo Lag: The Extreme Guide Quote
How can you be sure that it won't cause problems again?
'Another question: Under what conditions did you test the ease of shifting? In my case, it was very smooth as long as the engine was cold, but it became more difficult when the oil temperature reached 50°C.'
I recommend installing an LDA and, using a large syringe, re-checking the VTG.
Translated on 27-10-2026, 5:54.
No new posts Turbocharger ALH: Performance & Upgrade Diesel Engine Technology
No new posts Touran 2017: 2.0L SCR, 150 HP - DPF Issues & Turbo Lag Diesel Engine Technology
No new posts Extreme Russians at ASZ Motor Diesel Engine Technology
No new posts Audi A4: Severe Shaking/Jerking - AWX 130PS On-Board Diagnostics (OBD)
