Ford Galaxy: Limp Mode - Get Help Now!
andreasradinger
Post01-10-2009, 18:12    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
Hello, my Ford Galaxy, manufactured in 1996, is running in "limp mode."
and at idle, it has 1800 RPM.
Please help.
Thank you in advance.
icon_cry.gif icon_cry.gif icon_cry.gif icon_cry.gif icon_cry.gif icon_cry.gif
Translated on 14-10-2026, 1:15.
Post01-10-2009, 18:44    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
Reading the error codes with VCDS will tell you why.
andreasradinger
Post01-10-2009, 19:05    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
Error memory already read.
The preheating indicator light came on, but the brake lights are not working.
"And then we replaced the brake light switch, and after that, the engine went into limp mode."
"The gas pedal sensor has already been replaced, but that didn't solve the problem. The computer diagnostic showed..."
Mass airflow sensor was not defective either. Please help.
or does anyone know what needs to be soldered onto the circuit board for a bridge?
Translated on 14-10-2026, 1:16.
Post01-10-2009, 19:09    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
Um... please explain it again, in a way that's easier to understand. And what's currently stored in the error memory.
Translated on 14-10-2026, 1:17.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post13-10-2009, 20:53    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
I'd also like to know exactly what kind of errors it's producing. And, most importantly, which traces are you planning to solder and why???
Is the preheating light still blinking, and is the brake light switch being reported as faulty even though it's new? Is the brake light still not working?
If so, then check the wiring harness in the tailgate!
Passat Variant BGW 2005
Translated on 14-10-2026, 1:18.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-10-2009, 21:03    Subject: Ford Galaxy: Limp Mode - Get Help Now! Quote
Hi.
If replacing the brake light switch introduces another error, it is not properly calibrated. Please check bits 1-0 while applying the brakes; they should toggle.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts duesentausch NHG - need help Diesel Engine Technology
No new posts Golf 3 1.9 TDI: Glow Plugs Not Working? Diesel Engine Technology
No new posts Auxiliary Heater for Galaxy Car Diesel Engine Technology
No new posts Altitude Acclimation & Emergency Procedures On-Board Diagnostics (OBD)
