Siemens PPD: Self-Cleaning or Not?
Post05-07-2009, 11:10    Subject: Siemens PPD: Self-Cleaning or Not? Quote
Hi.
I drove a Lambda again yesterday.
It looked SIGNIFICANTLY better than the one from October 2008.
On October 8th, I still had software version 1184 on my MSTG device, but for some time now, it's been version 1881.
"It's supposed to be specifically designed to prevent sticking."
But why are the values so much better? Both times, the DPF was quite full, with 28% yesterday and a similar level in October.
Is there really no room for interpretation when calculating Lambda, that VW could have "adjusted" between 1184 and 1881?
 File size:  104.97 KB
 Viewed:  4398 times
Translated on 20-09-2026, 12:02.
Post05-07-2009, 11:23    Subject: Siemens PPD: Self-Cleaning or Not? Quote
Because the outside temperature was very high, and therefore the available air mass was smaller? icon_cool.gif
Translated on 20-09-2026, 12:03.
vagtuning
Post05-07-2009, 14:00    Subject: Siemens PPD: Self-Cleaning or Not? Quote
However, the 1881 has since been superseded by the 3783, and now by the 4369.
...I would be very interested to see the results of further tests.
Post05-07-2009, 14:25    Subject: Siemens PPD: Self-Cleaning or Not? Quote
Okay, on the way there, I didn't pay attention to the outside temperature.
Already on the way back:
 File size:  74.41 KB
 Viewed:  4019 times
Translated on 20-09-2026, 12:04.
Post04-10-2009, 21:14    Subject: Siemens PPD: Self-Cleaning or Not? Quote
10/3/2009
Software 1881.
Approximately 13 degrees Celsius outside.
DPF approximately 15% full.
I can confirm Rainer's summer explanation of lambda expressions with this.
The value is again higher than it was in July.
However, the 223 km/h shown on the speedometer is almost 240 km/h.
Hazards between the two construction sites of Nonnweiler and Birkenfeld.
I therefore don't have a general Vmax problem with PPD engines.
The lambda jump when reaching the 200 mark is caused by the engine control unit (ECU) itself.
There's a brief surge in the VTG (variable turbo geometry), causing a momentary spike in boost pressure.
See:
 File size:  67.86 KB
 Viewed:  3345 times
Translated on 20-09-2026, 12:06.
Post05-11-2009, 10:52    Subject: Siemens PPD: Self-Cleaning or Not? Quote
dieselmartin wrote:
3.10.09
Software 1881.
Hello Martin,
"Just out of curiosity - and because I'll probably be driving one of those cork-like vehicles myself in the medium term:"
How does the soot level in the DPF change after such a high-speed run?
Translated on 20-09-2026, 12:08.
Post05-11-2009, 14:41    Subject: Siemens PPD: Self-Cleaning or Not? Quote
Hi Roger,
It's hard to put into words.
At loads ranging from partial to full load, two opposing mechanisms play a role.
1. High load == a lot of Russian traffic -> the filter gets clogged.
2. High load == high temperature == spontaneous combustion -> filter burns off.
The diagram in the BOSCH diesel engine management system illustrates how engine speed and load are divided into 5 zones, and it explains the different regeneration strategies for each zone.
"Recently, I was lucky enough to find it parked outside with a 0% charge and 0 km since its last regeneration. After driving 40 km on the highway, it was still showing 0%."
Translated on 20-09-2026, 12:09.
Post05-11-2009, 20:55    Subject: Siemens PPD: Self-Cleaning or Not? Quote
I have a feeling this is going to be another Tamagotchi that needs constant attention icon_lol.gif icon_lol.gif...
Translated on 20-09-2026, 12:10.
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Fixing Errors: Does It Resolve Itself? On-Board Diagnostics (OBD)
No new posts 1.6 TDI Injectors: Siemens Remanufacturing? Diesel Engine Technology
No new posts Siemens PPD Verkokungsproblem und Düsenupdate Diesel Engine Technology
No new posts Idle vibration on 2.0 TDI 4V engine with Siemens PPD 1.5 Diesel Engine Technology
