"On the magnetic valve for boost pressure limitation, there are two hose connections and an electrical connector on the top. However, one of the two hose connections (located in the center of the valve) doesn't have a hose attached?! Can anyone tell me if a hose is supposed to be connected there, and if so, where it should lead to?"
Thank you and best regards.
Thomas. Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 01-10-2026, 14:10.
