Micha2005 Guest
09-11-2009, 14:02 Subject: J248 Connector Pinout & Location: Find It Here! |
Hello everyone,
I am looking for the location of the diesel engine control unit (J248) in my 2005 Touran with the BKD engine, as well as the pinout diagram for the connectors.
I thought the J248 would be similar to the J220 in the middle water tank.
I haven't removed the plastic trim yet because I wasn't sure how to do it, and I wasn't certain if it was actually located underneath. If it is underneath, what's the best way to access it, and how do I remove the trim?
Can anyone help me with this?
Where can I find the pinout diagram?
The engine control unit part number is: 03G 906 016 HK.
Component and version: R4 2.0L EDC G000AG.
Micha
Translated on 22-09-2026, 15:29.
09-11-2009, 14:39 Subject: J248 Connector Pinout & Location: Find It Here! |
Taking the water tank off.
- Peel the sealing strip from the metal edge and apply it to the engine compartment.
- If necessary, remove the retaining clips of the impeller housing (the plastic cover).
- Remove the windshield wiper arms.
- Detach the wind deflector from the windshield.
et voilà... the control unit.
m; Transparency, Teamwork
Translated on 22-09-2026, 15:30.
Profile PM Garage |
Micha2005 Guest
09-11-2009, 16:08 Subject: J248 Connector Pinout & Location: Find It Here! |
Wow, thank you, that was fast.
But before I can even start, I need a plan for the plug.
Does anyone have a link they can share with me?
I am particularly interested in the connections for the G70 mass airflow sensor and the N18 EGR valve.
Micha
Translated on 22-09-2026, 15:31.
lichti Blaumann
Joined: 09/07/2009 Posts: 46 Karma: +2 / -0 Location: PC-Österreich 2007 Volkswagen Golf Premium Support
16-11-2009, 14:46 Subject: J248 Connector Pinout & Location: Find It Here! |
94-pin connector at J248.
Pin 82 sw --> Pin 5 LMM
40 sw/li --> 4 LMM
60 grams --> 3 liters per minute.
13 br/ge --> 6 N18
I hope I could help you!
Best regards, EX-Golf V GTI Edition30, Oettinger Abgasanlage - Chiptuning
EX-3BV Passat Variant Business Comfortline, AVB, Bj. 2003
6J1 Seat Ibiza Cupra, CAVE, Bj. 2010
Translated on 22-09-2026, 15:32.
Profile PM Garage |
Micha2005 Guest
16-11-2009, 18:18 Subject: J248 Connector Pinout & Location: Find It Here! |
Hey, thanks, you got it!
Micha
Translated on 22-09-2026, 15:33.
