Right Angle Finder: Accurate & Easy Measurement
Post07-12-2009, 20:53    Subject: Right Angle Finder: Accurate & Easy Measurement Quote
Hi.
is the straight-angle constantly being learned... and is the initial learning just a starting value?
I had to recalibrate the alignment angle on the Golf after disconnecting the battery for a long time and replacing the steering column control unit.
I know for sure that the brake control module (BCM) reading showed 0.00 degrees.
Now, a week later, the steering assist module shows a value of -0.70 degrees.
Translated on 05-10-2026, 3:22.
