Reduce torque
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post15-12-2009, 22:09    Subject: Reduce torque Quote
Hello, is it possible to reduce the torque or power of the four-cylinder ALH engine in the MSG 038 906 018? Possibly by reprogramming to an automatic transmission?
Again, the clutch icon_sad.gif.
reflexsilber met.
Post15-12-2009, 22:23    Subject: Reduce torque Quote
Do you have a version with switchable settings, or is it a different car?
LMM deduction = Emergency program with reduced fuel injection volume.
RedR32
Avatar-RedR32
Post15-12-2009, 23:04    Subject: Reduce torque Quote
I don't have a diagnostic system available right now, but the invoice date was March 25, 2008.
That was still in Emskirchen icon_smile.gif.
"Disconnecting the plug would be too extreme; he'd only be able to go a maximum of 120 [km/h]."
reflexsilber met.
Post16-12-2009, 9:07    Subject: Reduce torque Quote
Well, how about getting a new clutch? I thought the reduced torque was only meant as a temporary measure, until a new one could be installed.
For a generally lower torque output, the dataset would need to be adjusted.
RedR32
Avatar-RedR32
Post16-12-2009, 17:40    Subject: Reduce torque Quote
Less excitement? Oh no, that's completely unacceptable.
Then I'll have to get a stronger clutch pressure plate. Oh dear, my left leg is already hurting.
The ValeoKit lasted exactly 0.5 years icon_evil.gif.
reflexsilber met.
langstreckenheizer87
Post16-12-2009, 18:18    Subject: Reduce torque Quote
rebuilding with a sintered clutch, inquiring about Sachs models icon_wink.gif
Back to top Profile PM Email
No new posts Reduce engine wear with magnetic oil drain plug General Tips
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
This topic is locked, you cannot edit or reply. Anregung - Wir senken den Benzinpreis! Transmission, Chassis, Body & Interior
No new posts MSW: Disassemble or Reduce Fuel Injection On-Board Diagnostics (OBD)
No new posts Nano-Additiv soll den Kraftstoffverbrauch signifikant senken Transmission, Chassis, Body & Interior
No new posts Torque AJM 6-G Diesel Engine Technology
