Loose radio on VCDS
Post28-12-2009, 21:16    Subject: Loose radio on VCDS Quote
Hi.
Can I connect an RCD500 that only has power to the CAN pins of my VCDS cable?
I mistakenly left it configured for a "sound system," and now I want to use it outside of a vehicle.
Translated on 12-07-2026, 1:08.
Octavia_4x4
Post03-01-2010, 22:26    Subject: Loose radio on VCDS Quote
Normally, that should work because the device is directly connected to the interface via the CAN bus lines.
I would still prefer to connect it directly to the car again and then reprogram it.
Translated on 12-07-2026, 1:09.
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts Radio dead On-Board Diagnostics (OBD)
No new posts Radio Beta V Diesel Engine Technology
