diesel.gustav wrote: |
| Are you actually referring to the nozzles themselves? Or are you referring to the nozzle holders, including the nozzles? |
Hello Gustav.
Well, it's the part that you can normally pull out of the cylinder head
as a whole after removing the injector lines and the retaining claws.
Correctly, it should probably be called a nozzle holder combination.
