dieseldusel Guest
14-05-2003, 13:26 Subject: Polo diesel with a gasoline transmission??? |
I have a diesel gearbox (CEG) from a Polo 3, which is unfortunately difficult to find. Does anyone know if there's an equivalent version for a gasoline engine (possibly the AEB?), and whether it could be used as a replacement?
Thank you.
Translated on 12-07-2026, 14:31.
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
14-05-2003, 13:29 Subject: Polo diesel with a gasoline transmission??? |
Profile PM WWW Garage |
dieseldusel Guest
14-05-2003, 13:33 Subject: Polo diesel with a gasoline transmission??? |
I understand that, but it's not explicitly stated that the AEB engine has the same translations/drive axles. It's just not listed as a gasoline engine option... or does that mean it won't work for installation?
Translated on 12-07-2026, 14:32.
Cord Schrauber
19-05-2003, 1:23 Subject: Polo diesel with a gasoline transmission??? |
Hi there.
I mean that the right-hand side Gelwave flange is longer on the CEG unit.
"However, it's quite clear; if that's the case, you need to install the flange from the CEG into the AEB and that should do it. Otherwise, everything should fit."
