sporadischer Leistungsverlust mit Log | Posts 16+
Go to page: Previous  1, 2
neubaupe
Post29-03-2010, 19:50    Subject: Quote
Today, I measured the individual reading for the ambient pressure (channel 10), and it's at 1023.
The value seems okay. - Ambient pressure: sea level.
Kann jemand etwas zu den logs / xls sagen? Speculations?
Best regards.
peter
Translated on 09-09-2026, 15:34.
neubaupe
Post29-03-2010, 23:23    Subject: Quote
I love this forum!
It consists of the three 'L's - Reading, Logging, and Learning icon_wink.gif.
The following symptoms are relevant regarding sudden clicking noises and log file analysis.
Possible catalytic converter damage if the engine is jacked up roughly.
More information to follow soon.
Symptoms: Loss of power, mainly in the higher RPM range, despite a presumably functioning mass airflow sensor (MAF) and correct boost pressure; sometimes, delayed boost pressure build-up in the lower RPM range.
Increased fuel consumption is possible, but usually there is no increased soot emission.
When reading the air mass values at full load, there may be an apparently inexplicable drop in the upper RPM range.
Knocking sounds (resonances) may originate from the direction of the exhaust.
Problems tend to arise more abruptly.
Common causes: The exhaust pipe's cross-section is narrowed due to fragments from a broken catalytic converter or due to an obstruction.
Tests: Tapping test (knocking?) on the exhaust near the catalytic converter.
Troubleshooting by: Replacing defective exhaust parts.
-->>/viewtopic.php?t=3285<<--
Translated on 09-09-2026, 15:36.
neubaupe
Post31-03-2010, 18:59    Subject: Quote
Test drive without a catalytic converter:
Unfortunately, there has been no change in the performance loss.
Translated on 09-09-2026, 15:38.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 TDI Intermittent Power Loss, AFN Engine On-Board Diagnostics (OBD)
No new posts Audi A6 Avant TDI: Intermittent Power Loss, 192k Miles Diesel Engine Technology
No new posts Intermittent power loss with VCDS log Upload
No new posts TDI: Intermittent Power Loss - Troubleshooting Diesel Engine Technology
