Sensor definitely defective?
Post04-04-2010, 17:52    Subject: Sensor definitely defective? Quote
Hi.
I actually wanted to check if the motor had just started a regeneration cycle, and I took the opportunity to create another "start log" using a different battery.
I noticed something strange in the log.
(Background: Approximately 14 km driven, regeneration has been running for 485 seconds, the vehicle was just parked to retrieve a laptop.)
Is it clear that the sensor is broken?
 File size:  64.57 KB
 Viewed:  1322 times
Malte1408
Post04-04-2010, 20:43    Subject: Sensor definitely defective? Quote
The timeline is not labeled.
Post04-04-2010, 22:27    Subject: Sensor definitely defective? Quote
The timeline is not labeled...
Sure, blame it on Excel.
You can tell when the process starts by the increasing voltage.
The entire log is 30 seconds long.
The jump from 50 degrees to 89 degrees occurred within 70 milliseconds.
Malte1408
Post04-04-2010, 22:34    Subject: Sensor definitely defective? Quote
It could also be a loose connection with a contact resistance. But I would still start by replacing the sensor.
Are you sure it's 90°C? Since the engine was running before and only stopped for a short time?
Post04-04-2010, 22:47    Subject: Sensor definitely defective? Quote
Okay, Excel has been conquered, and a scatter plot has been implemented.
Yes, those 90 degrees are definitely correct.
I've now also reviewed all the other logs containing temperature data, and they are all fine.
It was a huge coincidence that I saw the jump.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AWX: Faulty LD Sensor - Troubleshooting Upload
No new posts Faulty Turbo, Mass Air Flow or Oxygen Sensor? Diesel Engine Technology
No new posts Coolant Temp Sensor Failure: Jerking/Hesitation? Diesel Engine Technology
No new posts MAP Sensor for AKN Engine On-Board Diagnostics (OBD)
