Valve Guides & Stem Seals: Questions & Answers
haehnlein
Post21-05-2003, 18:23    Subject: Valve Guides & Stem Seals: Questions & Answers Quote
Hi DIY enthusiasts,
I'm currently in the process of replacing the valve stem seals on our Audi TDI 1Z with 270,000 km (the cylinder head is removed). During the process, one valve guide was slightly damaged (it's not perfectly round due to the pressure from the pliers) icon_evil.gif. However, the valve fits in without any problems. Is it a serious issue if the valve guide is slightly out of round in the upper area? Shouldn't it have little influence on the valve movement? icon_question.gif icon_confused.gif Also, the valve stem seal is located above it.
Unfortunately, I don't have a foolproof method for removing those pesky valve stem seals on the TDI. How do you do it? Do you use those Hazet pliers or the Matra tool? With the good old TD, at least you could remove the seal along with the valve spring retainer and then knock it out externally icon_rolleyes.gif.
Perhaps it's time to put a new head on the LL icon_razz.gif? Well, never change... Besides, we all want to know how long something like that lasts icon_smile.gif.
Thank you very much in advance }.
____________
Kein Auto mehr!
Translated on 31-10-2026, 3:57.
haehnlein
Post27-05-2003, 20:33    Subject: Valve Guides & Stem Seals: Questions & Answers Quote
So, the engine is running smoothly -> it seems like there's no problem icon_cool.gif.
For expanding the valve stem seals, I recommend the Hazetzange 791-8 icon_exclaim.gif icon_exclaim.gif. It worked very easily with it icon_wink.gif.
____________
Kein Auto mehr!
Translated on 31-10-2026, 3:59.
Varianti
Post28-05-2003, 18:36    Subject: Valve Guides & Stem Seals: Questions & Answers Quote
I don't think you can squeeze the valve guide with pliers. If you somehow managed to do that, the valve definitely wouldn't fit properly anymore, because a valve guide is designed to provide a precise fit.
I always use a Facom pliers (they're not cheap, but they work quite well). However, they only help you grip the object; you still have to do the pulling yourself.
More importantly, you need the right tool and the right technique to avoid damaging anything. If you damage the sealing lip or the piston ring (which isn't always immediately visible), the whole process will be useless.
Translated on 31-10-2026, 4:00.
haehnlein
Post28-05-2003, 19:43    Subject: Valve Guides & Stem Seals: Questions & Answers Quote
Varianti wrote:
So, I don't think you can squeeze the valve guide with pliers.
If you somehow managed to do it, the valve definitely shouldn't fit anymore, because that's a precision fit.icon_confused.gif
Hi Varianti,
I first tried using a regular pair of pliers, but the excessive pressure slightly damaged the valve guide. However, the valve went in without any problems -> so it shouldn't be a problem
Varianti wrote:
I always use a Facom pliers (it's not cheap, but it works quite well).icon_razz.gif However, it only helps you to grip the object. You still have to do the pulling yourself.
Sure... but the Hazetzange is very good
Varianti wrote:
However, what's more important is that you have the right tool or the right feel for striking. If you damage the sealing lip or the piston ring (and this isn't always immediately visible), the whole process was for nothing.icon_exclaim.gif
To protect the sealing lip, there is a protective sleeve that is fitted onto the valve. To push the seal in, I use the insertion tool from Matra (8mm valve stem). However, the seal does not need to be hammered in icon_wink.gif. A little pressure is enough, and you can feel how the seal settles in the lower area }.
____________
Kein Auto mehr!
Translated on 31-10-2026, 4:02.
No new posts Valve Stem Seal: Questions & Answers Diesel Engine Technology
No new posts Valve Guide Problems: How to Diagnose Diesel Engine Technology
No new posts AHU Damper Actuator Unavailable? Diesel Engine Technology
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
