ECU Replacement: AJM Engine - How To Guide
daniel_bf
Registered VCDS User
Post01-04-2010, 17:21    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Hello everyone,
I have a full version of VCDS and I want to replace the engine control unit (ECU) in my Golf IV (my chipped ECU with a stock ECU from a friend who has the same part number).
"Of course, I've already found some guides for this project, but I'm not sure which WFS (Vehicle Security System) I have right now. The original Hatta speedometer had an IMMO 2 system, which I replaced last year with an IMMO 3 speedometer. Does my engine control unit (ECU) have a WFS2 and my instrument cluster (KI) have a WFS3, or how should I interpret that?"
It would be great if someone could give me some tips on this, as I don't really understand how immobilizers work yet.
Daniel.
PS: I'm not sure what data you need right now, so here are a few details about my Volkswagen Golf for you:
GOLF IV Highline
85kW TDI PD
Engine: AJM
Transmission: DRW
Year of manufacture: 2000, Month of manufacture: 2001.
Translated on 17-08-2026, 9:33.
chli1976
Post01-04-2010, 21:25    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Normally, the Immo 2 MSTG system does not require a login for MSTG access.
Okay, read and save STG 17 adaptation channel 10 and channel 00.
VCDS
Translated on 17-08-2026, 9:35.
mullemaus
Post02-04-2010, 23:22    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Normally, with Immo 2 MSTG, there is no login within the MSTG system.
So, read and save channel 00 and adaptation value 10 for STG 17.
STG 17 is the speedometer! Therefore, it's located at address 01 in the main control unit (MSG).
Translated on 17-08-2026, 9:36.
chli1976
Post03-04-2010, 5:43    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Can I find information on Ross-Tech?
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
VCDS
mullemaus
Post03-04-2010, 9:31    Subject: ECU Replacement: AJM Engine - How To Guide Quote
What has nothing to do with the fact that you have to delete the learning values in 01. The MSG then retrieves the data from the speedometer. Without that, it will start and immediately shut off again. icon_cool.gif
Translated on 17-08-2026, 9:37.
Wiesel
Post03-04-2010, 10:20    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Hi Mulle,
I'm afraid you've got it wrong icon_wink.gif.
As far as I recall, it's similar to what Sebastian described: the AI learns from the MSTG.
Micha
mullemaus
Post03-04-2010, 10:43    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Hi Mulle,
Best regards, Micha.
This is possibly the normal case. icon_cool.gif I personally had approximately 15 cases where it didn't work without learning values in adaptation address 01. icon_wink.gif
Translated on 17-08-2026, 9:38.
Wiesel
Post03-04-2010, 13:15    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Funny...
Specifically regarding the 85kW PD models (which are... unique icon_wink.gif)?
I've never had any issues with MSA15, EDC15V, or EDC15P+ (okay, there weren't that many Immo2 systems).
what is reset in the MSTG.
Micha
Translated on 17-08-2026, 9:40.
daniel_bf
Post03-04-2010, 14:09    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Um, yes. I already found that page http://wiki.ross-tech.com/wiki/index.php/Immobilizer. But now I want to know which procedure I need to use to configure it.
According to the instructions for WFS2 or WFS3.
MSTG has the number:
038 906 019 CJ
AI:
VDO part number 1J5 920 826 C.
I need the login codes for both STGs for WFS3, which I don't have yet. It would be bad if it then stopped working; I need it to commute to work, and my friend does too. icon_wink.gif
Daniel
Translated on 17-08-2026, 9:41.
mullemaus
Post07-04-2010, 14:55    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Only the speedometer is the WFSIII. The pairing process should follow the standard procedure for WFS II!
Translated on 17-08-2026, 9:42.
daniel_bf
Post10-04-2010, 16:01    Subject: ECU Replacement: AJM Engine - How To Guide Quote
It worked flawlessly with the technology of WFS2!
Best regards, Daniel.
Translated on 17-08-2026, 9:43.
daniel_bf
Post13-04-2010, 5:00    Subject: ECU Replacement: AJM Engine - How To Guide Quote
hello
I've noticed that my cruise control is no longer working since I installed the new MSTG (module). Do I need to re-calibrate it, or does the new module not support the cruise control?
I'm sorry, I'm typing on my phone, so I can only use lowercase letters.
best regards, daniel
Post13-04-2010, 7:26    Subject: ECU Replacement: AJM Engine - How To Guide Quote
Do you need to activate it if the old vehicle didn't have it?
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 17-08-2026, 9:44.
daniel_bf
Post13-04-2010, 12:00    Subject: ECU Replacement: AJM Engine - How To Guide Quote
ok. thank you.
Are there any other things I need to specifically teach the car? Regarding future servicing, etc. I thought all of that would be stored in the combined instruction manual.
Wiesel
Post13-04-2010, 12:38    Subject: ECU Replacement: AJM Engine - How To Guide Quote
No - nothing else. The rest IS (and remains) in the AI icon_wink.gif.
Translated on 17-08-2026, 9:45.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts ECU Replacement: AXR Engine Control Unit On-Board Diagnostics (OBD)
No new posts Replace Engine Control Unit (ECU) On-Board Diagnostics (OBD)
No new posts Audi engine control unit (ECU) AAT - engine On-Board Diagnostics (OBD)
No new posts Question about engine control unit from G3 ABS motor 1H09... On-Board Diagnostics (OBD)
